C6500 Dist Fwd Card
andrewerowley
Is any data/config info on the cat6500 dist fwd card, I need to RMA one and due to security can not return any item that includes any info on it at all. i would be grateful for any information on this before I RMA this card.
satish_zanjurne
Level 4
Level 4
what item you are going to return ??
If it SUP, what is model number ??
WS-F6700-DFC3B (CAT6500 Dist Fwd Card, 256K Routes for WS-X67XX.
Hi ,
See the link below , it will give some useful information of this card..also to get the serial number,status, product ID of this card in the switch you can use "show module" & "show inventory" command
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_bulletin0900aecd8017a5db.html
HTH..rate if helpful
