C6500 VSS, ACE and RHI
I am planning VSS installation with one ACE and FWSM per physical chassis. As FWSM is "behind" the ACE I have
no problem using RHI, but I was wondering is RHI supported in VSS scenario or not?
VIP Super Bronze
Re: C6500 VSS, ACE and RHI
Hi Pavel,
There is no interoperability between FWSM Release 4.0 RHI feature and VSS integration
Here is the document
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/product_bulletin_c25-478751.html
Now, this is based on older IOS version of SXI and don't know if it is integrated in SXI4a.
Reza
Hello Reza,
thank you for your reply, but I must admit that I am a little bit confused (this is because I don't have hands on experience with ACE and RHI), but I am wondering, why should I care if FWSM does not support RHI, as in my case ACE would have a "direct connection" to MSFC, so FWSM is behind ACE, and is not problem for RHI to work, or I am terribly wrong?
Pavel,
Are you running the FWSM in transparent mode or a routed mode?
Jeremy
Hi Jeremy,
we are running FWSM in routed mode.
488
