%C6K_PLATFORM-2-PEER_RESET: RP is being reset by the SP *** System received a Software forced crash *** signal= 0x17, code= 0x24, context= 0x46ad8e04 PC = 0x42af7e5c, SP = 0x44d3c068, RA = 0x416c13fc Cause Reg = 0x00003820,
CSCO11910340
Hi All ,
Please help here to to get this switch UP. Attaching log for information. If any one faced the same issue please let me how you resolved.
 Supervisor Engine 720 10GE 12.2(33)SXI10
CSCO11910340
Switch is C6509E with version  s72033-adventerprisek9-mz.122-33.SXI10.bin"
 Switch is in VSS .
Traceback messages are usually software issues. The version of software you are running (12.2(33)SXI10) is over 10 years old. I recommend you open a ticket with TAC.  They will most likely recommend an upgrade.
Hi Reza ,
Thanks for your reply. Please provide me recovery process from rommon mode for IOS.
Can i try s72033-boot-mz.122-33.SXI10.bin boot image 1st to make up this switch then i can upgrade to latest   one.
Please share process document for recovery.   Really appreciate your support.
Thanks in advance !!
Thanks and Regards,
DRS
