Bronze
C6k with 6748 - Qos
on the 6748 blade, one port only connect to a gig port microsoft server, I want to set the speed at 100kbps...yes, you heard right 100kbps. Can I use any CatIOS Qos to do this? If not 100Kbps, what is the minimum bw?
Silver
Re: C6k with 6748 - Qos
hi!
You can follow the following guide to police at micro-flow level. but policing with catos works only for a L3 switching engine and wont work if you have just a L2 switching engine.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/configuration/guide/qos.html#wp1073161
regards,
Niranjan.
(please rate helpful posts)
Bronze
I have CatIOS, not CatOS. Is there another solution?
Thx
Hall of Fame Super Bronze
300
