Community Member
c805 erase flash: does't work
I'd like to upgrade the IOS:
Mr_Bb#sh flash:
Directory of flash:/
0 ---- 49096 Nov 8 2000 04:37:53 +01:00 TinyROM-1.4(1)
66 -r-x 6229492 Mar 18 2008 04:29:07 +01:00 [c805-osy6-mw.123-26.bin]
8388608 bytes total (2031616 bytes free)
Mr_Bb#erase flash:
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erase of flash: complete
Mr_Bb#copy tftp: flash:
Address or name of remote host [192.168.2.8]?
Source filename [c805-osy6-mw.123-26.bin]?
Destination filename [c805-osy6-mw.123-26.bin]?
Accessing tftp://192.168.2.8/c805-osy6-mw.123-26.bin...
Loading c805-osy6-mw.123-26.bin from 192.168.2.8 (via Ethernet0): !
Build [dchih 26] -- Mon Mar 17 20:29:03 PDT 2008
File name: c805-osy6-mw
RAM size: 0x00d5b579 (14005625)
Raw size: 0x00ca05d9 (13239769)
Image size: 0x005f0df4 (6229492)
%Error writing flash:c805-osy6-mw.123-26.bin (Not enough space)
Mr_Bb#sh flash:
Mr_Bb#
Why can't I erase the flash?
TIA,
Hall of Fame Super Gold
Re: c805 erase flash: does't work
Try either the following:
1. delete /f /r flash:[c805-osy6-mw.123-26.bin]
Note: Is this even the right filename???
2. delete /f /r flash:c805-osy6-mw.123-26.bin
When either one is completed, see if you have the command "squeeze flash:".
If none of the commands work, the next command will COMPLETELY WIPE OUT your flash drive: format flash:
Hope this helps.
Community Member
In the filename the problematic is the [] signs?
Yes, sh flash: shows the mentioned filename.
Your 1 and 2 options didn't do anything.
Can I use format flash: if this is the content of flash?
Mr_Bb#delete /f /r c805-osy6-mw.123-26.bin
Mr_Bb#sh flash:
So the question is: What will be with TinyROM-1.4(1)?
TIA,
The "format flash:" command will completely wipe out your flash.
Community Member
Then what can I do with the TinyROM file?
The router is far from here ...
TIA,
Community Member
Oh!
There isn't format command!
Mr_Bb#format ?
% Unrecognized command
Hmmm...
TIA,
1. You can copy TinyROM-1.4(1) to your TFTP server.
2. I can't believe "format flash:" is not supported on a 12.3 IOS when it's already present in the 12.2 IOS.
3. Try "squeeze flash:".
Community Member
1. OK, I hope I can copy it. What will it be effected to the running router?
2. I copied the result what I got from the IOS for "format" command.
3. I'll make a try.
TIA,
I have no idea what the "TinyROM-1.4(1)" filename is for and I'm sure it has nothing to do with the operation of your router.
Community Member
OK. We don't know what is TinyROM and it is needed or not. But what about erasing the flash:?
Squeeze flash:
Mr_Bb#squeeze flash:
All deleted files will be removed. Continue? [confirm]
Squeeze operation may take a while. Continue? [confirm]
Squeeze of flash complete
Mr_Bb#sh flash:
I think it is a little bit funny I can't remove the image.
TIA,
287
