C857 and vlans
Hi people,
I'm trying to configure a second vlan on my router.
That worked, but I can't find the commands to attach 2 of it's interfaces to this new vlan.
I would expect switchport access, but the newest ios doesn't give me this option.
I've put c850-advsecurityk9-mz.124-15.T13.bin on it.
Is there another .bin I need to use, am I using the wrong approach, or is it simply impossible to do??
Many thanks in advance
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: C857 and vlans
Won't help.  The 850 supports only ONE VLAN.  870 and the latest routers, 860, 880 and 890 support multiple VLANs.
Don't forget to rate useful posts (even though I gave you bad news).  Thanks.
Re: C857 and vlans
Hi people,
See the below link for vlan configuration on cisco 850 series
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/dhcpvlan.html#wp999406
Hope to Help !!
Ganesh.H
Re: C857 and vlans
Re: C857 and vlans
I was afraid of that, thanks for the confirmation.
Re: C857 and vlans
Thanks for the ratings.
1075
