02-05-2014 10:31 PM - edited 03-07-2019 06:02 PM
HI friends,
i have a setup for my small network like:
ADSL ---------- Router (2901) --------- catalyst Switch (2960) -------- LAN User (Data+VOIP+WLAN)
Router Config:
ip dhcp pool Data
network 172.16-.1.0 255.255.255.0
default-router 172.16.1.1
dns-server 192.168.1.1 4.2.2.2
ip dhcp pool Voice
network 172.16.2.0 255.255.255.0
default-router 172.16.2.1
ip dhcp pool WLAN
network 172.16.3.0 255.255.255.0
default-router 172.16.3.1
interface gigEthernet0/1
description Facing the ISP (the ADSL Modem)
ip address dhcp
ip nat outside
i did (show dhcp server) and got an ip address from the ADSL modem for this port ------192.168.1.2
interface gigEthernet0/0
description ****Facing LAN*****
no ip address
ip nat inside
interface gigEthernet0/0.1
description ****Facing LAN-Data*****
ip address 172.16.1.1 255.255.255.0
encapsulation dot1q 1 native
interface gigEthernet0/0.2
description ****Facing LAN-Voice*****
ip address 172.16.2.1 255.255.255.0
encapsulation dot1q 2
interface gigEthernet0/0.3
description ****Facing LAN-WLAN*****
ip address 172.16.3.1 255.255.255.0
encapsulation dot1q 3
access-list 1 permit 172.16.0.0 0.0.0.255
ip nat inside source list 1 interface gigethernet0/1 overload
ip router 0.0.0.0 0.0.0.0.0 gigethernet 0/1
Switch Config:
int vlan 1
Description***Data**
ip address 172.16.1.2 255.255.255.0
int vlan 2
Description***Voice**
ip address 172.16.2.2 255.255.255.0
int vlan 3
Description***WLAN**
ip address 172.16.3.2 255.255.255.0
ip default-gateway 172.16.1.1
int gig 1/0
description *****Connected to Router*****
switchport mode trunk
int fa 1/0
switchport mode access
switchport access vlan1
switchport voice vlan 2
Above is the config that i configure on router and switch but unfortunatelt internet does not work from any pc connected to the switch
i checked from router (sh ip nat translation) but output showing nothing.
same router is being used as CME also ang having the voice over ip configuration on it.... is that is the problem ?
atteched file is show version of the router if needed to check plzi am getting ip address on pc but not able to browse.
while i can browse when connect to the modem direct with cable to my pc
any suggestion and idea will be very appreciated! and i need urgent help plz
thanks
Solved! Go to Solution.
02-06-2014 01:19 AM
You shall issue "ip nat inside" command under the subinterfaces not on the main interface.
And one more thing permit 172.16.0.0 0.0.0.255 will only allow to translate 172.16.0.x adresses
no ip address
ip nat inside
ip nat inside
ip nat inside
access-list 1 permit 172.16.0.0 0.0.255.255
02-06-2014 02:14 AM
1° get rid of this static default route, you don't need it(because dhcp installed it already) and furthermore using a static route with a multipoint outgoing interface either poses problems or doesn't work if the next-hop has got proxy-arp disabled.
no ip router 0.0.0.0 0.0.0.0.0 gigethernet 0/1
2° specify your subinterfaces as nat inside interfaces
3° change your NAT ACL
no access-list 1 permit 172.16.0.0 0.0.0.255
Alain
02-06-2014 03:41 AM
Can you post the actual config you have on your router ?
Can you change your default route to -
ip route 0.0.0.0 0.0.0.0 192.168.1.1
Jon
02-05-2014 11:58 PM
Hello Waseem,
One thing that jumps out at me is that you are getting a private address (192.168.1.2) on your WAN port (gi0/1).
It looks like your ADSL modem is also functioning as a router/gateway, and you are experiencing a double NAT situatiuon. Since the ADSL router does not know that your 172 networks reside behind the 2901 the traffic never returns.
You could possibly add a static route for each network to the ADSL router, but the better option would be to get the ADSL modem fully bridged, so that your 2901 gets the public IP address itself.
I was also wondering what default gateway you are using for each VLAN. It looks like you have a trunk configured with sub-interfaces on the 2901, so those IPs (the .1s) should be your default gateways.
Let me know if that works,
Christopher Ebert
02-06-2014 12:24 AM
thanks for your reply Christopher.
this make sense that you said, and i guess this is the problem, because ADSL modem has NAT enabled on it and i am also enabling NAT(PAT) on my router.
since router got private ip address from Modem that's why it is not being translated my private IP(s) with modem,
because translation would only be happened with public IP.
so you suggest to configure static routes in ADSL Modem itself ?
i ll try that.....
is there any other possible solution for this to let local LAN work with modem ??
thanks
02-06-2014 01:19 AM
no ip address
ip nat inside
ip nat inside
ip nat inside
02-06-2014 01:24 AM
I would start basic troubleshoot from insisde hosts side. So start ping you default gateways of particular subnets 172.17.1.1, 2.1 and 3.1 if you ping succesfully then ping inside address of you ADSL modem(192.168.1.1). Also I would recommend you to not use DHCP between your ADSL and 2901 router. It does not make sense. You can use static addressing or switch your ADSl modem to the bridge mode.
Another thing is that you do NAT on your Cisco router so you don't need add static route on ADSL becasue all your insisde subnets are translated to outside interface Ip address(assigned from DHCP) and ADSL modem know where to direct return traffic.
Also ip nat insisde is missing on insisde interfaces
Next please chceck DSN resolution if it works.
Jan
02-06-2014 02:14 AM
Alain
02-06-2014 02:50 AM
i did all the steps mentioned above and here they are
change acl to 0.0.255.255
add ip nat inside in subinterfaces
configure a static ip address on modem connected interface on the router
now i can ping that interface(router outside int) ip address from my LAN witch (connect to router)
but still not able to browse.
any idea please
02-06-2014 02:53 AM
Please try to ping 8.8.8.8 from the router with source 172.16.1.1 and please do the same from the pc.
I think you have problem with DNS resolution.
02-06-2014 03:03 AM
HI,
i tried but no luck
Router#ping 8.8.8.8 source 172.16.1.1
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.1.1.1
Success rate is 0 percent (0/5)
02-06-2014 03:19 AM
where is the 10.1.1.1 address coming from ?
Do you have anything configured with that address on the router ?
Jon
02-06-2014 03:24 AM
HI,
yeah actually 10.1.1.1 is reall address but i am saying 172.16.1.1 in the forum.
my mistake ,,,,, did not edit it well
02-06-2014 03:31 AM
Okay but 10.x.x.x addressing is also private addressing so could you post the actual config you are using as you may be making typos when you modify it for the forum.
Can you do the following -
1) from a client on the switch ping the clients default gateway (which should be the subinterface IP on the router not the IP address on the switch)
2) from same client ping the WAN interface on the router
3) from the same client ping the cable modem and check the NAT table with "sh ip nat translations"
see what works and also can you say what the client IP is.
Jon
02-06-2014 03:44 AM
HI,
C:\Users\2013>ping 10.1.1.1 (G.W)
Pinging 10.1.1.1 with 32 bytes of data:
Reply from 10.1.1.1: bytes=32 time<1ms TTL=255
Ping statistics for 10.1.1.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\2013>ping 192.168.1.2 (WAN INT)
Pinging 192.168.1.2 with 32 bytes of data:
Reply from 192.168.1.2: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.1.2:
C:\Users\2013>ping 192.168.1.1 (ADSL IP)
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=63
Ping statistics for 192.168.1.1:
Ethernet adapter Local Area Connection: (IP Client got)
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connecti
on
Physical Address. . . . . . . . . : 00-29-BE-BB-37-PE
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::992:e551:c2e5:1061%11(Preferred)
IPv4 Address. . . . . . . . . . . : 10.1.1.11(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Thursday, February 06, 2014 1:34:35 PM
Lease Expires . . . . . . . . . . : Thursday, February 13, 2014 2:11:19 PM
Default Gateway . . . . . . . . . : 10.1.1.1
DHCP Server . . . . . . . . . . . : 10.1.1.1
DHCPv6 IAID . . . . . . . . . . . : 234889676
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-2E-3C-58-00-29-BE-BB-37-PE
DNS Servers . . . . . . . . . . . : 192.168.1.1
4.2.2.1
NetBIOS over Tcpip. . . . . . . . : Enabled
02-06-2014 03:46 AM
So you can ping the modem from a client.
What about trying an internet address from the client ?
Jon
02-06-2014 03:27 AM
HI
i even can not ping with the source of outside interface...
Router#ping 8.8.8.8 source gi 0/1
Packet sent with a source address of 192.168.1.2
any idea please?
thanks
