Cabling AGAIN!
There is a grid in some of the books giving you the types of cable to connect to different devices, where is it? or where can i get it? thanks in advance.
Re: Cabling AGAIN!
I don't know of this grid you speak about... Care to tell us what devices you are connecting?
-Chris
Re: Cabling AGAIN!
Any Devices, ie switches to switches requires a straight through RG45 but switch to a router needs a crossover etc etc there is a grid which gives you the devices down the left nd across the top then in the middle it tells you which type of cable to connect each device with
Re: Cabling AGAIN!
DTE to DTE = Crossover (Hub/Switch to Switch/Hub)
DCE to DCE = Crossover (PC to Router)
DTE to DCE = Straight through. (Hub/Switch to PC)
106
