Community Member
Calling all SUP card experts...
Hi everybody,
I'm running diagnostics on various supervisor cards ona 6509 chassis and have found that several of the cards are showing this same problem:
System Bootstrap, Version 7.1(1)
Copyright (c) 1994-2001 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
c6k_sup2 processor with 262144 Kbytes of main memory
rommon 1 > boot
loadprog: bad file magic number: 0x0
boot: cannot load "bootflash:"
rommon 2 >
rommon 1 > boot
rommon 2 > dir slot0:
Directory of disk0:
2 38282452 -rw- c6k222-psv-mz.122-18.SXD7b.bin
rommon 3 > boot bootflash:c6k222-psv-mz.122-18.SXD7b.bin
open(): Open Error = -9
loadprog: error - on file open
boot: cannot load "bootflash:c6k222-psv-mz.122-18.SXD7b.bin"
I can't believe that all the cards have the same problem so i tried them (at least 4 different ones) in a 6000 series chassis but get the same problem.
I tried loading a different IOS image on the PCMCIA card but no joy.
The only one that i got to load showed the following:
System Bootstrap, Version 5.3(1)
Copyright (c) 1994-1999 by cisco Systems, Inc.
c6k_sup1 processor with 65536 Kbytes of main memory
Autoboot executing command: "boot bootflash:"
Exit at the end of BOOT string
rommon 1 > boot
rommon 2 > dir bootflash:
File size Checksum File name
13514 bytes (0x34ca) 0x883b31c9 DSDSW01.cfg
13514 bytes (0x34ca) 0x883b31c9 run
13514 bytes (0x34ca) 0x883b31c9 start (deleted)
6304109 bytes (0x60316d) 0x5fd7b46a RTSYNC_RTSYNC_cat6000-sup.5-5-1.bin
rommon 3 > boot bootflash:RTSYNC_RTSYNC_cat6000-sup.5-5-1.bin
Uncompressing file: ####################################################
System Power On Diagnostics
DRAM Size ....................64 MB
Testing DRAM..................Passed
NVRAM Size ...................512 KB
Level2 Cache .................Present
System Power On Diagnostics Complete
Boot image: bootflash:RTSYNC_RTSYNC_cat6000-sup.5-5-1.bin
In Local Test Mode, Synch Failed. Retries: 4
WARNING: Pinnacle has not synchronised
Local Test Mode encounters Minor hardware problem in Module # 1
Is this because i haven't got the latest IOS? Any ideas on why the others aren't operational? Any help would be appreciated.
1 REPLY
Community Member
Re: Calling all SUP card experts...
Is u r router able to boot without any cards installed?
also post the set command output
163
