Can a VS-SUP720-10Gig run a Sup720-10Gig 12.2(33)SXI IOS?
geraldjacksontx
When I try to load plain IOS 12.2(33)SXI5 I get:
Waiting (slot 5) for supervior to come online in other slot.
I thought when I ordered this configuration that I could run without VSS.
I am glad to help you finding the answer.
Please rate and mark the question answered if it is so. This will help others too.
Best regards,
Alex
6 Replies 6
Reza Sharifi
The Sup-720-VS is capable of running VSS, but You don't have to run VSS.
Is your sup in slot 5?
What version of IOS are you currently running?
I not running anything. I should have backuped the original code, but I
did not.
geraldjacksontx
It looks like a bug in 12.2(33)SXI5.  It boots fine with 12.2(33)SXI8.
But still why do the Hardware Supervisor say configured for VSS.  I thought that was only Software.   Are there difference between VSS configured Sup720-10G and Sup720-10G.
That does answer it. Thanks. I was just worried that I ordered a VSS
dual sup, because of cost and not the function. Since it would not boot
with code that I using elsewhere.
To: Cecil Jackson
Date: 11/14/2011 03:27 PM
Subject: - Re: Can a VS-SUP720-10Gig run a Sup720-10Gig 12.2(33)SXI IOS?
Best regards,
Alex
