Can an N2K 2248TP-E work with an N7K
The N2K data sheet says that it doesn't, but I want to confirm that it isn't old information.
Does anyone have this working and what versions are you using?
Glenn
  • LAN Switching and Routing
Everyone's tags (5)
Re: Can an N2K 2248TP-E work with an N7K
yes I have one working, running 5.2.1 code
Are you sure you are not referring to just a 2248TP.  Cisco TAC just told me that the N7K does not support 2248TP-E and that is what the N2K data sheet shows.
Sorry, my error - I did not notice the "-E"on the model number.
Hi Glenn
Currently it's not supported, but planed in future.
HTH,
Alex
What is the difference? Whats the "E" for?
read the below URL
http://be.comstor.com/documents?documentId=43381&filename=CiscoNexus2248TP-E+FAQ.docx
1033
