05-03-2012 04:07 AM - edited 03-07-2019 06:28 AM
I'm on a Cisco 2955 switch and need to get ssh workgin which I have done on another 2955 (but don't have near me), what am I dogin wrong?
2955-02-PJ-CamdT.LU#sh run
Building configuration...
Current configuration : 4061 bytes
version 12.1
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname 2955-02
logging buffered 64000 debugging
no logging console
aaa new-model
enable secret 5 $1$6eSD$eB19P9CoH6VPNejFp5/
username admin privilege 15 secret 5 $1$wPVm$ptIpMJbGxRlv1hwe.D.
clock timezone GMT 0
ip subnet-zero
no ip domain-lookup
ip domain-name SO-DGI
ip ssh time-out 120
ip ssh authentication-retries 3
ip ssh version 2
no file verify auto
(removed)
line con 0
line vty 0 4
transport input ssh
line vty 5 15
no exec
end
2955-02#
The error I get is:
login as: admin
password:
Access denied
Driving me mad, any ideas?
05-03-2012 04:14 AM
Andy,
You need to have aaa configured:
aaa authentication login default local
You have aaa new-model enabled, so you should just need to configure the above.
HTH,
John
05-03-2012 04:28 AM
Along with John's statement make sure you have created the crypto keys also .
05-03-2012 07:20 AM
Hi john,
by default the authentication method DEFAULT is applied to the line when aaa is enabled so no need to add the command.
Regards.
Alain
05-03-2012 04:39 AM
Think I have this solution, I didn't know you couldn't copy and paste the secret encrypted passwords over, I copied over in clear text and it was fine!
