Can hsrp track two ip addresses?
tom_chan
Simple question - can hsrp track two ip addresses? Meaning it tracks the first ip address first and then the second ip address, and if both ip addresses are unreachable, then hsrp will kick in.
ashok gouda
I feel it is possible.i do not have the rite equipment with me to simulate the above scenario but when i tried on packet tracer i could use track commands for both interfaces .
The above is my view,please share with me if my answer is incorrect and u get a correct answer.
Ashok
It can be done, one needs to configure a track list.
See
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/sweot.html#wp1078768
One thing to keep in mind if you track more than one interface is that each interface that goes down will decrease the priority by an amount. You want to assign the priorities to the interfaces such that one interface will be primary/active. The decrease of one interface going down should not make the active interface lower priority than the standby. It should take the decrease of both interfaces to become less than the standby.
Rick
Rick
thanks
