04-04-2012 08:22 AM - edited 03-07-2019 05:57 AM
Hi all,
I was trying to enable AutoQoS on my router 3925 GE interfaces, but failed to do so !! But I was able to do so on FE interfaces !! I have Security/K9 and Data/K9 license on this router. Or do I still miss out anything ?? I am on IOS 150-1(M4). Please advise.
I was able to enable AutoQoS on all my Cisco 2811 and 1841 routers !!
Best regards,
Lawrence Chew
04-04-2012 09:05 AM
Lawrence,
Your going to have to manually configure a policy for that interface. Autoqos isn't supported on that interface.
Take a look at this document for interface types autoqos is supported on and other required info to run it.
http://www.cisco.com/en/US/docs/ios-xml/ios/qos_auto/configuration/15-2mt/qos-auto-15-2mt-book.html
Chad
04-04-2012 09:26 AM
Hi Chad,
Thanks for the speedy reply. From the document you provided mostly show low speed interface like serial or ATM and Frame-Relay. I can't see the example on GE interface.
So far I am not able to turn on AutoQoS on my GE router interfaces. No issue on FE interfaces on the same routers.
Best regards,
Lawrence Chew
04-04-2012 10:55 AM
The doc doesn't mention it becuase it's not a supported interface.
The 3925 only has built-in Gig ports unless your just running them at 100Mbps. Or do you have a switch module that has your FE interfaces? Could be that the switch module has support for it similar to regular switch.
HTH.
Chad
