10-27-2014 09:03 AM - edited 03-07-2019 09:15 PM
I have read that they need to have the same number of slots (for 4500E), anyway, that would be the case. I have IPBase for both switches.
Thanks for your help,
Sergio L.
10-27-2014 09:30 AM
VSS is available on a Catalyst 4500-X switch and on chassis that support Supervisor Engine 7-E and Supervisor Engine 7-LE.
Note The two chassis must have the same number of slots. However, +E and -E chassis can be mixed.
see table-5-1 in this link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/vss.html
11-06-2014 07:23 AM
You probably don't really know what these P/Ns are.
These aren't modular switches and they DO support VSS.
10-27-2014 02:36 PM
In addition to Reza's post, Sup8E also supports a new type of VSS, Easy VSS.
