11-03-2014 05:52 AM - edited 03-07-2019 09:21 PM
I am trying to connect 1G uplink from remote switch to 2960X 10G sfp port, but not able to change the port speed to 1G, as a result uplink is not coming up. Is it possible to reduce the 10G SFP module speed to 1G in 2960X switch
11-03-2014 12:40 PM
No, that is not possible. You would need to use the same type of SFPs and speed on both sides.
11-04-2014 05:58 AM
You will need to replace the 10Gb SFP with a 1Gb one as it will not negotiate down.
The ports on the 2960x are SFP+ meaning they should support both 1Gb and 10Gb SFP's.
