Can I remove "call-home" setting on Cat6500?
snakayama
Level 3
Level 3
Hello everyone,
I want to remove the following "call-home" setting from configuration (NVRAM) or stop it from showing by show runn command on Cat6500 12.2(33)SXH4.
Is it possible or I can't remove it?
If possible, could you please let me know how can do it.
call-home
alert-group configuration
alert-group diagnostic
alert-group environment
alert-group inventory
alert-group syslog
profile "CiscoTAC-1"
no active
no destination transport-method http
destination transport-method email
destination address email callhome@cisco.com
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
subscribe-to-alert-group diagnostic severity minor
subscribe-to-alert-group environment severity minor
subscribe-to-alert-group syslog severity major pattern ".*"
subscribe-to-alert-group configuration periodic monthly 26 14:24
subscribe-to-alert-group inventory periodic monthly 26 14:09
I understand the default setting of Call Home feature is disabled, but I want to remove it.
Thanks and regards,
Shinichi
Lucien Avramov
Level 10
Level 10
Smart Call Home should be disabled by default.
The global config command 'service call-home' enables it. It's available from 12.2(33)SXH
No service call-home will disable it, however the actual call-home block cannot be removed from the configuration.
Here is a good call home configuration link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/con
figuration/guide/callhome.html#wp1119728
8 Replies 8
Lucien Avramov
Level 10
Level 10
Thank you very much for your reply.
I understand it.
Thanks and regards,
Hi Snakayama,
How u removed the Cisco Call Home configuration in the NVRAM..
I tried but only the service was disabled..
Let me Know ..
Thnks&Rgds
Senthil
Hi Senthil,
I could not remove Call Home setting so Call Home setting is still existing in the NVRAM ...
Shinichi
Hi there,
You can remove the whole config and block from call-home with command: "clear config call-home"
Cheers
Hi, right on this platform, or you saw/managed somewhere else? Got inspired to try on ISRv image, but no such option..
did you actually try your suggestion? Clear config is usually an ASA thing.
Take care…
The "no call-home" command in global config should take the call-home information off on the configuration.
