Can I run TCL inside EEM?
All,
I want to run a TCL script inside EEM applet. The process will b:  I capture the log like "neighbor down" and run some configuration command. Immediately after that, the TCL script starts running. TCL script is monitor the link by simply ping a IP for several times and regexp the successful rate. After that TCL script running finish, I want to run some configuration command again. Then this applet is finished. Is it possible to run a predefined TCL script from the FLASH inside the EEM applet? Is there any good guide? Thanks!
Lou
369
