05-17-2007 10:47 AM - edited 03-05-2019 04:08 PM
I have a 6500 with a WS-X6724-SFP blade
in it and IOS 12.2(18)SXE3.
I need connect a 3750 switch to one of the SFP ports on the blade. This 3750 switch will have PC's and IP phones connected and will have a data and voice vlan.
data vlan = 6
voice vlan = 910
I want to make the ws-x6724 port a routed port with sub-interfaces for the two vlans. The commands take, but I cannot ping the switch, nor can the switch ping the router port.
I remove the sub-interfaces, re-address the primary interface and I can ping the switch.
Config with sub-interfaces that does not work:
interface GigabitEthernet3/24
no ip address
interface GigabitEthernet3/24.6
encapsulation dot1Q 6
ip address 161.2.6.1 255.255.255.128
Config without sub-interfaces which works:
3750 switch config:
All interfaces are:
switchport access vlan 6
int vlan 6
ip address 164.72.6.15 255.255.255.128
ip default-gateway 164.72.6.1
Can the ws-x6724-sfp do sub-interfaces and if so why do you think I can't ping the switch?
05-17-2007 10:52 AM
Hi Friend,
I believe the reason is when you create sub interface you are specifying dot1q tag for vlan 6 but on 3750 switch the port is configured as an access port which will send the vlan 6 traffic without any tag and cat 6k subinterface will drop the traffic.
So try to configure the 3750 switchport as trunk port and allow vlan 6 only or on the subinterface dot1q command specify native keyword after vlan number something like this
encapsulation dot1Q 6 native
Try this and update if it works.
Ankur
*Pls rate all helpfull post
05-17-2007 04:46 PM
Thats the hard way to do it , just create your layer 2 vlans on each side then create the corresponding layer 3 SVI's . Then create your trunk link between the 2 switches. Don't really get your addressing your vlan 6 addresses on each side are in different subnets so I don't know how it could work at all . on the 6500 it is in the 161.2.6 and on the 3750 it is 164.72.6 .
05-18-2007 06:35 AM
I made a mistake on the IP address in the 3750 switch - it should be:
int vlan 6
ip address 161.2.6.15 255.255.255.128
ip default-gateway 161.2.6.1
Thanks for you ideas and I'll give it a try also.
