Can I terminate 40 Mbps DSL BROAD BAND connection in Cisco 800 series routers
ajay1komban
Dear all,
 Can I terminate 40 Mbps DSL BROAD BAND connection in Cisco 800 series router?.It is not a leased line.
Which Router model is best for 40 Mbps DSL Broad band termination ?
Thanks&Regards
Ajay Jose K
Hi ,
 Below link provides you all model in 800 series .
http://www.cisco.com/c/en/us/support/routers/800-series-routers/tsd-products-support-series-home.html
For your requirement below model should suffice .
Complete throughput from the router is 51 Mbps .
Cisco C891FW Integrated Services Router
Sandy
7 Replies 7
Hi Jose ,
  Below datasheet give you performance of router series . What is your user capacity connect behind this router ??.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Sandy
Hi santhosh,
        Thank you for your response
    But that model routers not available.I have to terminate ppoe connection.
http://www.cisco.com/c/en/us/products/routers/800-series-routers/models-comparison.html
Thanks&Regards
Ajay Jose K
Share me Show version or Part Number for your router .
Sandy
Hi Sandy,
 I have to purchase router. I want  to configure PPOE inside that router.
 It is 40 Mbps broad band connection.From ISP optical device we will get ethernet output.
We should terminate this ethernet connection our cisco device.Costomer demanding Cisco800 series router.
Ajay
Hi ,
Sandy
Dear sandy,
Thank you for your reply
Thanks&regards
Ajay
Dear sandy,
 Cisco C891 is not available in this market.
  Can I go with 881k9 model ?
   is it support  40 mbps DSL connection ?
Ajay Jose K
