can I use my interface Ip address for a nat pool?
patricianet
can I use my interface Ip address as the source ip for nat?
interface f0/1.40
ip address 192.0.40.10 255.255.255.192
ip nat outside
interface f0/1.70
ip address 192.0.70.10 255.255.255.192
ip nat outside
ip nat pool Data 192.0.40.10  192.0.40.10  prefix-length 26
ip nat pool VoIP 192.0.70.10 192.0.70.10 prefix-length 26
Nagaraja Thanthry
Yes, you can use the interface IP for NAT overloading. Instead of using a pool, you can also use "interface" keyword if you are just using the interface.
ip nat source list interface overload
Hope this helps.
NT
Ganesh Hariharan
interface f0/1.40
ip nat outside
interface f0/1.70
ip nat outside
yes you can do the same check out the below sampole configuration on the above case.
http://www.firewall.cx/downloads/articles/sample%20config%20using%20ip%20nat.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
