Can not ping anywhere from Cat65
pt_wang
Why I can not ping anywhere from Cat65.
No access-list filter icmp on Cat65.
14 Replies 14
andrew.prince
Level 10
Level 10
Check your SVI interfaces are up check your static/dynamic routes
It is fail to ping even the clients on all directed connected interfaces.
post your config for review - remove sentitive information.
Here is.
check
vlan access-map icmp 10
match ip address 194
action drop
vlan access-map icmp 20
match ip address 192
action forward
So see if the source/destination of the pings is allowed.
I was remove acces-list 194.Did not fixed.
Acess-list 192= permit ip any any
Do you think it will fix?
What is the source IP address you are using for the ping? what are the desitinations? Is it all VLAN's or just some?
From Cat65( not specify) or any VLAN's IP addresses to any hosts on(within) Cat65 VLANs.
Sorry this makes no sense.
let me ask you this - from a host on a any of the vlans can you ping the Cat?
When you ping a host from the cat using a source IP of the cat does this also fail?
I can not ping from hosts on any VLANs to Cat.
ping a host from the cat using a source IP of the cat does fail too.
Only hosts to any hosts(any VLANs) works fine.
check
action drop
action forward
I will try tomorrow due to I can not access to my customer cat now.
I take out this two vlan access-map.But problems is same- can not ping from cat.
I revise my previous email -
I can ping from hosts to cat.
Andrew,
I fix it this morning.I take out "mls qos". Thanks for your help anyway.
