can't change native vlan on trunk port ?
pmello
I have several closets with Cisco 3560 on the edge that I'd like to change the vlan that's used for the management
vlan on each. In the core I have a Cisco 6509 with Sup720's.
I'd like to do this by changing the native vlan on the trunk port on the core 6509 interface that connects to the 3560.
and leave the management vlan on the 3560 as vlan 1.
Seems trivial but what I tried didn't work and I didn't have the window to troubleshoot. I'll paste the simplified configs
for  the interfaces  below, any suggestions would be appricieated.
Pete
6509 configs:
interface Vlan50
ip address 172.16.50.2 255.255.255.0
interface FastEthernet 8/22
switchport
switchport mode trunk
switchport trunk native vlan 50
no ip address
3560 configs:
interface FastEthernet0/24
interface Vlan1
ip address 172.16.50.100 255.255.255.0
5 Replies 5
jimmysands73_2
Level 5
Level 5
Why would you want to have native vlan mismatches?
And why dont you have
for fa0/24?
Curious Jim.
Currently I have over 200 switches all using the same vlan for management, topology is 2 to 6 switches stacked in each closet with with about 50 closets. Uplinks are fiber or ehternet depending on closet, all are dual homed with an uplink from
each of the dual 6509's in the core.
That's a huge spanning tree loop and I've see unstability when I get a bounce or when we loose power and UPS's die and then all get powered up at the same time.
My thought is that insteaad of going into each closet and creating the vlan for management, adding the VLand interface ect ect, I can just change the Vlan1 IP to match whatever the vlan is for that closet then in the core set the native vlan for management to that rack.
Even if it's not the recommended what to go I'd still like to know why it's not working.
Sent from my Android phone using TouchDown (www.nitrodesk.com)
glen.grant
  you can try  on the 6509 to remove vlan 50 from the trunk , "switchport trunk allowed vlan remove 50"  . It may still be trying to tag vlan 50 because it is allowed in the trunk.  It doesn't need to be allowed in the trunk if you are making it the native (untagged vlan) . Still not a great idea.  Going to make it a nightmare to try and troubleshoot if you have issues mixing vlan 1 and 50 together .
Jonathancert_2
From knowledge and experience, learned that point-to-point trunks will not route if the native VLAN is mismatch.  If the 3560 is in transparent mode, you should still be able to mismatch the management VLAN'S once you correct the native VLAN mismatch.  Symptoms are misleading.  Trunks will be up/up but unable to ping.
Jonathan,
