Can't get DHCP on 2611
Hello all,
I want to setup e0/0 on my 2611 to recieve DHCP address from my ISP (Comcast). I tried several variations of "ip address dhcp" on int e0/0 and nothing worked. The port is up, but NOT plugged in. Does that matter, because if it doesn't, I can't seem to setup DHCP and that's a major concern. Bottom line is that the IOS won't take the command...
On a side note, here's the IOS info:
Hercules#show ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(27b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 16-Aug-05 17:55 by pwade
Image text-base: 0x80008088, data-base: 0x80833630
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
And yes, I'm somewhat of a Cisco newbie!
Thanks!
Chris
1 REPLY
Re: Can't get DHCP on 2611
You are currently running 12.1(27b) which is quite old and may not have all the feature u require.
If you have CCO id you better can run download the newer version so that you can have the required command configured..
You can refer this link for finding out the same..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
210
