Community Member
Can't get out to web on 877
Hi. I'd like to give my laptop a public IP and my 877 a public IP for test purposes.
However i seem to be falling over at the first step, my router can't seem to ping any sites. Here's the config. Any ideas?
Building configuration...
Current configuration : 3284 bytes
version 12.4
no service pad
hostname inetrtr
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
ip cef
ip domain name yourdomain.com
ip name-server 62.x.40.178
ip name-server 194.x.0.98
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username micross privilege 15 secret xxx
archive
log config
hidekeys
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dialer0
ip address 217.34.x.x 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
no cdp enable
ppp authentication chap callin
ppp chap hostname hostname
ppp chap password 0 password
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Community Member
Re: Can't get out to web on 877
hi,
my sugsestion - change default route to IP address of gateway, route to interface Dialer with Your mask is bad idea
regards
romek
Community Member
hi mate, so you mean find out the gatway from our DSL supplier and make my default route that IP address?
Community Member
hi,
yes, route to interface is possible only on point-to-point connections
regards
romek
115
