Can't get vlan trunking to work
Okay I'm running a wsc2950c-24 switch and a 3640 router from cisco. And I follow the instructions they have on their site and I just can't get this thing to work prooperly.
The computer on Vlan 1 has an ip of 192.168.4.100. The computer on vlan 85 has an ip of 192.168.5.101. I can't get 5.101 to ping anything on the switch. But on 4.100 I can get it to ping both router addresses and the switch address.
My config files are below:
Switch:
Using 2263 out of 32768 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname swtmw-em-test1
enable secret 5 XXXX
enable password XXXXX
ip subnet-zero
vtp domain XXXXX
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 81
name johdoe
shutdown
interface FastEthernet0/1
switchport access vlan 81
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
switchport trunk allowed vlan 1-90
switchport mode trunk
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface Vlan1
ip address 192.168.4.253 255.255.255.0
no ip route-cache
interface Vlan81
no ip address
no ip route-cache
ip default-gateway 192.168.4.254
ip http server
banner login ^C kdkakfjakjdflkjasdlkfjakjdsfla C
dddddddddddddddddddddddddddddddddddddddddddddddddddddddddd^C
line con 0
line vty 0 4
password netAdm1n
login
line vty 5 15
password netAdm1n
login
end
router:
Using 1358 out of 129016 bytes
version 12.2
hostname rtrmw-em-test
enable secret 5 XXXXX
ip subnet-zero
no ip routing
interface FastEthernet1/0
no ip address
no ip route-cache
speed auto
half-duplex
no mop enabled
interface FastEthernet1/0.1
encapsulation dot1Q 1 native
ip address 192.168.4.254 255.255.255.0
no ip route-cache
interface FastEthernet1/0.2
encapsulation dot1Q 81
ip address 192.168.5.254 255.255.255.0
no ip route-cache
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password netAdm1n
login
end
Re: Can't get vlan trunking to work
you have NO IP ROUTING on your router....you must enable routing, "IP ROUTING"
Silver
You dont have the IP address set on vlan 81, so how can the switch send traffic to/from this subnet, if it doensnt have a route for it?
Cheers,
LR
You have both of these configured for inter vlan routing. Try this config. Please look at the differences.
version 12.1
no service pad
ip routing
ip subnet-zero
vtp domain XXXXX
vlan 81
name johdoe
no shut
switchport access vlan 1
interface Vlan1
no ip route-cache
interface Vlan81
no ip route-cache
ip route 0.0.0.0 0.0.0.0 192.168.4.254
ip http server
line con 0
line vty 0 4
password netAdm1n
login
line vty 5 15
password netAdm1n
login
end
router:
version 12.2
ip subnet-zero
ip routing
speed auto
half-duplex
no mop enabled
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password netAdm1n
login
end
enable IP routing on the switch. Add IP to Interface vlan 84, set default route to the router, removed the sub interfaces of the router and assign it an ip. enable IP routing on the router as well.
Hall of Fame Super Bronze
Gentlemen,
The switch is a L2 switch.
The original poster should continue with the configuration in the router as its L3 device.
IP Routing is disabled in the router and it should be enabled for inter-vlan routing.
Also, devices on each subnet must point to the L3 interface in the router that belongs on that subnet.
HTH,
__
Edison.
This guy is right. I did all my config on the router and got it working. I did some stupid crap when I was configuring it and just reset it all.
Thanks for the help guys.
180
