08-19-2014 01:10 AM - edited 03-07-2019 08:26 PM
Dear All,
I don't know why but I can't ping the HSRP address 10.xx.xx.1 from BIO-N5K-22 and LIMS on the right side (see diagram in attachment). All other device are correct (ping ok)
VLAN 200
N5K-11: 10.xxx.xxx.2 (HSRP listen)
N5K-12: 10.xxx.xxx.3 (HSRP master 10.x.x.1)
N5K-21: 10.xxx.xxx.4 (HSRP bck)
N5K-22: 10.xxx.xxx.5 (HSRP Listen)
LIMS (Catalyst 3750x in level 2)
The network is in dual-homed with 2 peer-link (& keep-alive)between each device in the same room (11<-->12 and 21 <-->22). I checked all level 2 (vlan, interconnection, ....). I used the fabricpath mode for my vlans. I'm wondering if there is a problem with my configuration from my nexus.
Could you tell me if you have any idea ? I can give you more information if needed.
Thanks for your help.
08-19-2014 04:01 AM
hi m.durieux,
Can you share the following outputs from all the switches. You can attach the files separately for each device.
1. show run int vlan 200
2. show mac address-table vlan 200
3. show spanning-tree vlan 200
Ranganath
08-19-2014 06:23 AM
