Community Member
Can't ping HSRP virtual ip address
Hi all,
I'm testing HSRP in Cisco Packet Tracer, please download the attached file first.
in two Core switch, I have setup HSRP virtual ip address 192.168.1.254 in vlan 13, but switch1 or switch2 vlan 13 clients can't ping the HSRP virtual ip address, they only can ping the vlan 13 gateway ip address 192.168.1.252 and 192.168.1.253, please someone help !
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Perhaps this thread from the forum may be helpful. It is a very similar setup of HSRP in packet tracer and came to the conclusion that it is a flaw in packet tracer.
https://supportforums.cisco.com/thread/2254332
Rick
I don't have packet tracer. Can you post the configs from both of your routers/switches that has hsrp configured?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Rick
Community Member
Hi Richard,
Thanks for your reply, it is bug in PT
575
