Community Member
Can't see FXS card.
Hi;
I have 2811 router with serial & FXS cards.
I can't find the FXS card??
R1#sh ve
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Feb-06 16:37 by ccai
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.3(8)T6, R)
R1 uptime is 9 minutes
System returned to ROM by reload at 21:19:18 UTC Thu Apr 12 2007
System image file is "flash:c2800nm-adventerprisek9_ivs-mz.124-4.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1032A2CP
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Re: Can't see FXS card.
You might need an image that supports voice.
Check Table 3 at :http://www.cisco.com/en/US/products/ps5854/prod_bulletin0900aecd8017a816.html
Community Member
is the image c2800nm-adventerprisek9_ivs-mz
supported?
Waleed.
Looks like your IOS is IP-BASE. (From your sh ver) "C2800NM-IPBASE-M"
Check with your cisco partner if you got the right software. I *think* it should be "IP
VOICE" when you do a "sh ver". (Assuming you are looking for a IP Voice basic feature to be supported)
Community Member
Thanks.
but i have lash:c2800nm-adventerprisek9_ivs-mz.124-4.T2.bin image which is voice supported.
Community Member
I installed Voice image
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(12a), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 22-Feb-07 17:13 by prod_rel_team
R1 uptime is 31 minutes
System image file is "flash:c2800nm-ipvoicek9-mz.124-12a.bin"
export@cisco.com.
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Can you please post all Network modules you have in the router.?
Community Member
Slot0: WIC2T
Slot3: VIC2FXS
Here are a couple of things I would try
1) Move the FXS to a different slot and see if it comes up
2) Have the FXS module alone on the router and remove the WIC-2T. Once the router comes up, do a HOT insert of WIC-2T.
Community Member
Community Member
2800 series routers take the VIC2-2FXS, it is the version 2.0 of the FXS cards. The VIC-2FXS is for earlier series routers I believe. I use both in my enviroment, you will just need to make sure you get the version 2 FXS card.
239
