Community Member
can't telnet Cisco2950 - can access connected devices
I have a 2950 switch that connect my servers from 3 VLANs to the main switch (Cisco 3560)
all my switches use VLAN1 with 192.168.74.x IP, the main switch is also configured with IPs on each of the other 3 VLANs
PCs on the network can telnet any 74.x switch, well - not that one 2950
the 2950 switch can only be accessed from the other switches
what would cause it to block non 74.x IPs from accessing it???
1 REPLY
Hall of Fame Super Gold
Re: can't telnet Cisco2950 - can access connected devices
Ofir
The symptoms that you describe suggest that either the switch does not have a default-gateway configured or that the configured default-gateway is not correct. Can you post the switch config - or at least tell us what, if anything, the switch has for a default-gateway?
Rick
152
