Can't to VSS the C4500X-32 and C4500X-16
Hello.
I want to VSS the C4500X-32 and C4500X-16 but after configuring and rebooting the standby switch show the message:
*Jul 30 00:27:22.363: %C4K_REDUNDANCY-2-INCOMPATIBLE_SUPERVISORS: STANDBY:Active and Standby supervisor types are not compatible. Autoboot on the Standby supervisor will be disabled and the standby supervisor is returned to ROMMON.Early Notification of a Critical job [iosd] exiting abnormally! Initiating cleanup sequence.
Is it normal?
Thanks.
Everyone's tags (1)
Silver
Hi, On 4500X in orrder to
On 4500X in order to have VSS capability, the minimum software requirement is Cisco IOS XE Software Release 3.4.0SG. Please make sure that the 2 4500 have the same IOS-XE version on that release.
Hope this helps.
Hi,Hardware Requirement:VSS
VSS is network system virtualization technology that pools Two symmetric Cisco Catalyst 4500E chassis or two Catalyst 4500X-16 Series Switches or two Catalyst 4500X-32 Series Switches into one virtual switch
Software Requirement:
Cisco Release IOS XE 3.4.0SG and later releases support VSS
Refer:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/vss.html#wp1053927
Aru
*** Please rate if the post useful ***
Regards, Aru *** Please rate if the post useful ***
137
