04-29-2010 07:07 AM - edited 03-06-2019 10:52 AM
We want to setup VSS on our 2x 6509, we have the following modules in each 6509 chassis:
1x sup720-10g-3c
1x 6724-sfp
1x 6748-ge-tx
1x X6704-10GE
Can the VSL link be configured to only use 1x of the 10gb ports on the supervisor or is there a requirement for a 10gb etherchannel to run VSS ?
(We don't have enough available 10gb ports for running a VSL etherchannel)
Solved! Go to Solution.
04-29-2010 08:43 AM
1x sup720-10g-3c
1x 6724-sfp
1x 6748-ge-tx
1x X6704-10GE
Can the VSL link be configured to only use 1x of the 10gb ports on the supervisor or is there a requirement for a 10gb etherchannel to run VSS ?(We don't have enough available 10gb ports for running a VSL etherchannel)
It's only a recommendation to use both ports on the supervisor so yes you can do it with one but this is not recommended as VSS is designed to be a high availability system and you are reducing that by only have one link in the VSL. Ideally you should have a link in the VSL from another module as well.
Jon
04-29-2010 09:56 AM
In case of a split-brain situation when the VSL link breaks, the active control plane transitions to standby mode and disable all the linterfaces as in operational shut down state.
The dual active state is detected rapidly (subsecond) by any of the following three methods:
• Enhancement to PAgP used in MEC with connecting Cisco switches
• L3 Bidirectional Forwarding Detection (BFD) configuration on a directly connected link (besides VSL) between virtual switch members or through an L2 link through an access layer switch
• L2 Fast-Hello Dual-Active Detection configuration on a directly connected link (besides VSL) between virtual switch members (supported with 12.2(33)SXI)
HTH,
-amit singh
04-29-2010 08:43 AM
1x sup720-10g-3c
1x 6724-sfp
1x 6748-ge-tx
1x X6704-10GE
Jon
04-29-2010 09:50 AM
I see, so it works but not recommended...
What happens if that VSL link goes down/or all VSL links goes down? Does it introduce a split-brain scenario, or is there any type of traffic going through non-dedicated VSL links that can tell that both switches are still up and running, preventing split-brain/ duplicate ip/macs?
04-29-2010 09:56 AM
HTH,
-amit singh
04-29-2010 09:58 AM
Just to add to the post, in case the previous active virtual switch members transtions to standby state, the other switch which becomes the active virtual member have the active control and data plane and keep on forwarding the traffic.
04-29-2010 10:56 AM
Thanks, that clarifies my questions.
As we have 12.2(33)SXI3 we can use any of the methods you specified.
