Community Member
Can we configure Q-in-Q on WS-C3750-24PS
I have  WS-C3750-24PS  version 12.2(55)SE4.  I am configuring PBB VPLS.   MY PE/P routers are alcatel 7710/7750
my topology is like that.
CE1<-------> Provider_switch(3750)<-------> PE1 < ----IP/MPLS----> PE2<-------> Provider_switch(3750)<----------->CE2
  16                        11        11                             16
I can ping from CE1 to CE2 but on Wireshark i am unable to capture pakets of 802.1ad ( q-in-q). I tried on each location(ingress/egress) but no success
My switch 3750 configuration is like:
interface GigabitEthernet1/0/1   -----------------> connected to PE1/PE2
switchport mode trunk
interface GigabitEthernet1/0/2 -------------------->   connected to CE1/CE2
switchport access vlan 11
switchport mode dot1q-tunnel
no cdp enable
Somebody told me that  <switchport mode dot1q-tunnel> can support q-in-q but it will remove the tag at egress point. I try to configure a command
<switchport trunk dot1q ethertype 88A8> but i can't because no such command in that IOS
Can anybody help me.
Thankks
Community Member
Hi uzair,
Check this site below:
http://groups.geni.net/geni/wiki/QinqResults#Cisco
HTH.
Terence
Community Member
Hi Terrence,
               I checked that....but when i capture trace from 3750 switch(ingress/egress mirror/monitor)...i can't find 802.1ad packet....only 802.1q packets are comming on wireshark.
i don't know why.....because  is for that.....and it is working fine.....but 802.1ad packets are not comming on wireshark.
Community Member
hi uzair,
i think you might not be able to see the 802.3ad tag as this tag is removed before the packet is switched back to your network.
the .ad tag is only used on the SP switches as far as i know.
maybe this is why you dont see the .ad tag and only the .q tag.
regards,
florian
935
