07-09-2012 08:42 AM - edited 03-07-2019 07:40 AM
Dear all
We have cisco 2911/k9 we fixed 2 HWIC-4ESW crds in 2911. I create 4 vlan i have assigned 1 HWIC-4ESW all vlans are working fine
when i configure 5 th vlan it assigned second HWIC-4ESW 1 port but interface status showing up. i connected one system to that port i try
to ping that port that port notable to pinging is there any activation for that second HWIC-4ESW please suggest me.
Narsimha
07-09-2012 08:58 AM
May be i am wrong but just trying to understand your question:
What i understand is ..
You have created 4 vlans and you applied on the 4 ports of 1st HWIC-4ESW card.
Now you created 5th valn and applied to one of the ports on 2nd HWIC-4ESW cards.
Now you want to ping from vlan1(Port 1) to vlan5(port5)
Do you this topology??/
Usually you can insert 4 HWIC-4ESW cards.
07-09-2012 10:22 AM
Thanks for replay
interface FastEthernet0/0/0
description To RBS
switchport access vlan 10
interface Vlan10
description To RBS
ip address 10.236.112.65 255.255.255.224
ip nat inside
ip virtual-reassembly
I have connected desktop to 0/0/0
desktop ip add 10.236.112.68 255.255.255.224
gateway 10.236.112.65
i want ping this desktop to 10.236.112.65
07-09-2012 09:43 AM
Hi Narshima,
Yes you can have 2 No's HWIC cards in 2911 routers...
If that shows in your config... it should work... there might be some other problem..... Pls try reinserting the module once again.... check for inflow and outflow of packets in the inetrafces to chk the hitz
07-09-2012 10:32 AM
Thaks for replay
Two cards interfacess showing in router 1 card i have assigned 4 vlasn it's working fine 2 card first port 0/1/0 i have assigned vlan10. in this port i have conntected on pc that pc notable communicating vlan10
description To RBS
interface Vlan10
description To RBS
ip nat inside
07-09-2012 11:16 AM
can you please pase the whole config??
Then only we can find the problem.
sh run ?
07-09-2012 11:17 AM
Have you really connected the right port? Do a "show ip int brief" to verify which port is UP.
07-09-2012 07:56 PM
Hi, yes i am already using another 4 port in one more card this is the second card. But Port status is up Thanks, Narsimha
07-09-2012 11:55 PM
can you show us the your whole config??
07-10-2012 12:20 AM
Hi Narsimha
You have to connect these two modules with a crossovercable.
You also have to configure "stacking partner" to get it to work.
see this for reference
/Mikael
07-16-2012 10:45 AM
Thanks, same i have configured it's working but is it right?
07-16-2012 11:34 PM
Glad to here it's working.
Yes, the modules has to be connected by a crossovercable, because there is no backplane that connects the modules together.
/Mikael
