12-27-2007 11:12 PM - edited 03-05-2019 08:11 PM
Version 12.2(25)SEE4
IPSERVICES
access-list 100 permit ip 10.23.10.0 0.0.0.255 any
route-map rm permit 10
match ip address 100
set ip next-hop 10.23.7.1
c3750-01-core#conf term
Enter configuration commands, one per line. End with CNTL/Z.
c3750-01-core(config)#int vlan14
c3750-01-core(config-if)#ip policy route-map rm
c3750-01-core(config-if)#^Z
c3750-01-core#sho run int vlan14
Building configuration...
Current configuration : 239 bytes
interface Vlan14
ip address 10.23.11.1 255.255.255.0 secondary
ip address 10.23.12.1 255.255.255.0 secondary
ip address 10.23.10.1 255.255.255.0
end
WTF??? where is route-map?
12-27-2007 11:59 PM
What is the SDM template you are running on the switch? By default the switch runs desktop default template which can be verified using " SH SDM PREFER"
You would require an SDM routing template for PBR support. You would require a reboot to take the new setting into effect
Narayan
12-28-2007 12:09 AM
Thank you. I'll try when it will be safe to reload switch.
01-02-2008 08:25 AM
I've had similar experiences and contacted Cisco to ask about this... I was informed that I would need to upgrade my IOS to "Advanced IP SERVICES" version in order to get this feature.
01-05-2008 09:51 AM
royalblues is correct, also you do not need to change feature set:
Dugg for "WTF??? where is route-map?" :)
