Cannot connect remote TACACS
Tacacs is not working in switch WS-C3560V2-48PS with software version 12.2(55)SE7
Below are the ping test from switch.
I am confused about ping from switch.
Whats the different between both ping?
Switch#ping 10.49.250.13
Sending 5, 100-byte ICMP Echos to 10.49.250.13, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Switch#ping 10.49.250.13 source 10.132.16.8
Packet sent with a source address of 10.132.16.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 176/177/185 ms
Need your expertise.
Thank you.
 Hi,I see you are running
I see you are running ospf and have some static routes as well. Static route for 10.0.0.0/24 will be preferred for TACACS server 10.49.250.13 and 10.49.250.14, which is out of vlan 170
So when TACACS packet will go out it will take source as ip address of vlan 170 which is 10.132.17.8
So probably in the path some node is missing reverse route to 10.132.17.8. Arrange a source based trace to TACACS server (10.49.250.13) with source 10.132.16.8 and 10.132.17.8. that will lhelp to know which hop is not having reverse route for ip 10.132.17.8
interface Vlan1
 ip address 10.132.16.8 255.255.255.0
 ip helper-address 10.132.16.18
interface Vlan99
 ip address 138.218.170.214 255.255.255.252
interface Vlan170
 ip address 10.132.17.8 255.255.255.0
 ip helper-address 10.132.6.32
 ip helper-address 10.132.6.33
ip route 10.0.0.0 255.0.0.0 138.218.170.213
Akash
Akash,How do you check the
Akash,
How do you check the preferred route is out of VLAN 170 instead of VLAN 1.
Switch#traceroute
Protocol [ip]: 10.49.250.13
% Unknown protocol - "10.49.250.13", type "trace ?" for help
MYSBJ-LSW37#traceroute
Protocol [ip]:
Target IP address: 10.49.250.13
Source address: 10.132.16.8
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Tracing the route to 10.49.250.13
  1 138.218.170.213 0 msec 0 msec 0 msec
  2 138.218.170.209 8 msec 0 msec 0 msec
  3 138.218.170.246 0 msec 0 msec 0 msec
  4 138.218.170.230 8 msec 0 msec 0 msec
  5 138.218.219.226 8 msec 0 msec 8 msec
  6 138.218.218.193 168 msec 168 msec 176 msec
  7 138.218.218.45 176 msec 176 msec 176 msec
  8 10.51.1.73 185 msec 176 msec 176 msec
  9 10.51.2.226 177 msec 177 msec 176 msec
 10  *  *  *
 11  *  *  *
 12  *  *  *
 13  *  *  *
 14  *  *  *
 15  *  *  *
Protocol [ip]:
Source address: 10.132.17.8
Probe count [3]:
  2 138.218.170.209 8 msec 0 msec 9 msec
  4 138.218.170.230 0 msec 0 msec 0 msec
  5 138.218.219.226 0 msec 8 msec 0 msec
  6 138.218.218.193 167 msec 168 msec 176 msec
  8 10.51.1.73 176 msec 176 msec 176 msec
  9 10.51.2.225 177 msec 177 msec 184 msec
 10  *  *  *
 11  *  *  *
 12  *  *  *
 13  *  *  *
 14  *  *  *
 15  *  *  *
Thank you.
Hi,I checked below static
I checked below static route and was guessing that it was going out of vlan 99 but bymistake mentioned vlan 170.
Please take output of  show ip route 10.49.250.13 and also check sourcebased tracroute with source of exit interface.
-akash
41
