Community Member
Cannot establish dmvpn tunnel after implementing hsrp on hub routers
Hello Expert,
I testing HSRP and Dmvpn using two hub and three spokes.
I configured a hub and the spokes and implemented vpn tunnels , I fully tested same
and all my tunnels were established okay.
Next I  backup up my hub  config and restore same to a second router that will serve
as backup --- note I use the same ip address for both hub 1 and hub 2
I connected the two hubs and the three spokes.
On the two hub I configured HSRP and simulated a blackout of the primary hub while
running a continuous ping to a device connected to the lan side of one of my spoke.
There was a brief break in transmission and then my backup hub became active taking over the primary function.
The problem is when I check for my tunnels none was establish between hub and any of the spokes.
Attach is copy of hub ---- Note I using the same configuration for both hub – same ip address ?
Could any one please help.
170
