08-06-2013 07:25 PM - edited 03-07-2019 02:47 PM
hi everyone!
just bought sg200-26p switch and trying to configure it in the CLI environment but i cant telnet the switch, when i went through the switch using the browser i notice that there is no telnet available in the TCP/UDP settings. any idea how i can manage the switch using CLI. thanks
Sincerely,
Rolf
Solved! Go to Solution.
08-06-2013 08:42 PM
SG200 switches are only GUI configurable. The SG200E model only does support CLI.
08-07-2013 01:10 AM
Check Cisco 200 Series Switches Data Sheet
According to this document it support both trunking and up to 4 etherchannels simultaneously.
If my ansswers were helpfull, dont forget to rate them.
08-06-2013 07:28 PM
also i just upgraded it to the latest firmware, but still telnet not working.
08-06-2013 08:42 PM
08-06-2013 11:51 PM
Thanks, can i enable trunking or etherchannel on this switch? pls. let me know how.
Rolf
08-07-2013 01:10 AM
08-08-2013 02:35 PM
Wrong forum, post in "small business switches". You can move your post using the actions panel on the right.
