Cannot Uplink/Daisy Chain Cisco 2960 S Series Switch to Cisco 3750 Switch
I have a new Cisco 2960 S series switch with a basic configuration that needs to be uplinked or daisy chained to a Cisco 3750 switch. I am not getting any connectivity to the network with either a straight through or crossover cable. the port remains in amber but a 'show interface' indicates that the interface is up. I can manage the switch with a PC patched into any port on the switch with a static IP address. Must be something very simple that I am missing. Outlined below is the configuration.
Refresh_SW1#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE3,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 16:56 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWA
RE (fc1)
Refresh_SW1 uptime is 1 hour, 13 minutes
System restarted at 14:40:48 UTC Mon Feb 6 2012
System image file is "flash:/c2960s-universalk9-mz.122-55.SE3/c2960s-universalk9
-mz.122-55.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24PS-L (PowerPC) processor (revision D0) with 131072K bytes of m
emory.
Processor board ID FOC1551X07F
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : C4:0A:CB:52:12:80
Motherboard assembly number     : 73-11908-06
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC15496YHB
Power supply serial number      : DCA1546U1F5
Model revision number           : D0
Motherboard revision number     : A0
Model number                    : WS-C2960S-24PS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC15495WU9
System serial number            : FOC1551X07F
Top Assembly Part Number        : 800-30945-02
Top Assembly Revision Number    : C0
Version ID                      : V02
CLEI Code Number                : COMGE00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24PS-L   12.2(55)SE3           C2960S-UNIVERSALK9-M
Configuration register is 0xF
Refresh_SW1#sh run
Building configuration...
Current configuration : 1852 bytes
! Last configuration change at 15:53:49 UTC Mon Feb 6 2012
! NVRAM config last updated at 15:46:39 UTC Mon Feb 6 2012
version 12.2
no service pad
hostname Refresh_SW1
boot-start-marker
boot-end-marker
enable secret 5 ***************.
no aaa new-model
clock summer-time UTC recurring last Sun Mar 1:00 last Sun Oct 2:00
switch 1 provision ws-c2960s-24ps-l
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 128.100.100.110 255.255.0.0
ip default-gateway 128.100.1.1
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password *****
login
line vty 5 15
password *******
login
end
Refresh_SW1#
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cannot Uplink/Daisy Chain Cisco 2960 S Series Switch to Cisc
Amber could mean a few things:
1.  Spanning-tree;
2.  Auto-negotiation between access and trunk port.
Can you please post the config of the 3750?
If you'd like try the following command on each switches:
2960S
interface
switchport mode trunk
speed auto
duplex auto
3750
default interface
interface
switchport encapsulation dot
speed auto
duplex auto
Few questions:
1. From where are you trying to check the connectivity to the network?
2. 2960 is a L2 switch alone. so was the link b/w 2960 and the 3750 configured as Trunk?
3. use the cross over cable for connecting two switches.
4. from the switch can you ping the default -gateway 128.100.1.1 ?
-Vijay
Ans - From the LAN and a PC(static IP) patched into the switch.
2. 2960 is a L2 switch alone. so was the link b/w 2960 and the 3750 configured as Trunk? No.
3. use the cross over cable for connecting two switches. Tried that already
4. from the switch can you ping the default -gateway 128.100.1.1 ? No
Have you forced the port to full duplex and speed 100. Does the switch have a ip address. Are going to pass traffic thru this switch.
Have you forced the port to full duplex and speed 100. I will try that.
Does the switch  have a ip address. It does.
Are going to pass traffic thru this switch. Yes.
1.  Spanning-tree;
2960S
interface
speed auto
duplex auto
3750
default interface
interface
speed auto
duplex auto
Purple
Can you post the 3750 side of the config , really nothing  that should make it not work if you are just running an access port to the 3750 .  I would think about changing that masking  and making it something smaller .
Thamk you everyone for your comments. Spaaning tree was puuting the uplink port in a blocking state. I disable spanning tree and the problem was resolved.
Purple
   I would say that was not a wise decision , spanning tree put that port in blocking mode for a reason , somewhere you have a built in loop in your design and you could put your net at risk by shutting off spanning tree between devices.
2295
