Webcast-Catalyst9k
Cannot write to const_nvram 6509 - Sup720
My IOS: s72033-ipservicesk9-mz.122-18.SXF12.bin
I cannot do a: "copy tftp const_nvram:vlan.dat"
After a successful tftp transfer, the switch immediately responds with an error to the effect of , "cannot write to const_nvram".
This command works with this IOS, "s72033-jk9sv-mz.122-18.SXD7b.bin"
Any help would be greatly appreciated!
thanks,
Jason
Blue
Re: Cannot write to const_nvram 6509 - Sup720
In order to restore the vlan.dat file, complete these steps:
Copy the vlan.dat file into the device's NVRAM from a TFTP server or an external PCMCIA card.
copy tftp: const_nvram:
notice no vlan.dat file name present...
Reload the switch, as vlan.dat is read only during the booting process.
Victor
Tried that and still have the same problem
Here is what I typed.
copy ttp: const_nvram:
I got:
"%Warning: There is a file already existing with this name Do you want to over write? [confirm]
Cannot copy from vlan.dat to vlan.dat"
Dear Jason:
   Did you happen to solve the problem? I am facing the same issue. Thanks.
Did you manage to solve this issue ? I am having the same, i tried with a
erase const_nvram before the reload but with no luck.
Thanks in advance
Silver
Can you please post the "dir const_nvram:" command output.
Thanks&Regards,
Antonin
Hello Amikat,
Thanks for your reply, dir const_nvram says that vlan.dat
1     -rwx     0          vlan.dat
I also did a
Chassis#erase const_nvram
Erasing the const_nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of const_nvram: complete
Chassis#reload
//output....
but no chances, i get :
User Access Verification
Password:
Chassis>en
Chassis#copy bootflash:vlan.dat const_nvram:vlan.dat
Destination filename [vlan.dat]?
%Warning:There is a file already existing with this name
Chassis#exit
Thanks you in advance if you have any ideas...
best regards
Silver
Thanks for the reply.
Can you please try to use the command "delete const_nvram:vlan.dat" instead of "erase ..." and if succeed reload the switch and try again the "copy ..." command and see if there is any progress.
Best regards,
Antonin
Hi again, same issu when I use the delete command... I will make some tests today and let you know, I did follow the Cisco procedure, i do have all expected output (reset of the VLAN & VTP configuration) but still no way to copy the file.
I will keep you informed, regards
Silver
What is you vtp status? I would suggest to set it to "client" before deleting the vlan.dat.
Best regards,
Antonin
I tried to change the vtp status, no chance. I did upgrade the chassis to the same version as the originate vlan.dat, and that worked fine.
According to the TAC, this is not a software version issue, bug this might be bug
CSCsj71192.
VSL : Unable to replace vlan.dat file with Sierra image.
Symptom:
Conditions:
When attempting to copy vlan.dat file from disk0: to nvram: the copy is blocked and the console displays the error message "Cannot copy from vlan.dat to vlan.dat"
Workaround:
Downgrade to 12.2(18)SXF7 or upgrade to a release that integrates the fix.
1448
