Cascading 2 cisco 2960 switch
jahanzeb.feroze
Dear All,
I want to cascade two 2960 switch (Layer2) together, i have tried by making the ports trunk as well as access but it doesnt works, please help?
Jahanzeb Feroze
20 Replies 20
Ismael Dandashi
Dear Jahanzeb
Please check the link below
http://www.tek-tips.com/viewthread.cfm?qid=1583402
Thanks for sharing the link, but question asked in that link is still unanswered, no solution has been determined yet.
Could you expand on "doesnt works" in your OP?
And, as Jose already asked, could your provide configs and what ports you're actually interconnecting?
One port is of Gig, while other port is of Fa
Copper?
not copper, its ethernet cable
Ethernet can run across both copper or fiber - so what "kind" of Ethernet?
Fiber
If you are running fiber, what are the SFPs you are using please do a "show inventory" Usually fiber SFPs are either 100Mps or 1Gbps, if only going to a 100Mbps device then ensure the SFP in the Gigabit port will run at 100Mbps
Hi Jahanzeb,
- Did you set a native vlan?
// switchport trunk native vlan <Vlan-id>
Example:
interface GigabitEthernet<int>
 switchport mode trunk
 no sh
Regards.
Nopes i didnt, is that really matter to set the native vlan ?
The native VLAN will default to 1.  You don't need to configure it on either end, but if you configure it on one end you need to configure it on both ends.
Can you post the 2 config?
On first Switch,
 switchport trunk allowed vlan <Vlan-id>
On other Switch,
interface Fa<int>
These are the simple config on both switches
