Cascading 2 cisco 2960 switch
jahanzeb.feroze
Dear All,
I want to cascade two 2960 switch (Layer2) together, i have tried by making the ports trunk as well as access but it doesnt works, please help?
Jahanzeb Feroze
20 Replies 20
Have you created the VLANs being trunked on both switches, or just one of them?
Trunking a VLAN between switches is not sufficient to make it work.  You actually have to create the VLAN on both switches.
Philip D'Ath
Are the switches within 3m of each other, and are they 2960-X's ?  If so, a nicer solution is to buy the stacking modules and make them look like one larger switch.
yes they are with in 3m, cannot buy stacking modules, has to go with the same equipment which are already exists, one is 2960 while other is 2960 X
s.lachica
Hi Jahanzeb,
Here is a sample configuration for basic 2-switch connection.
PC1---(G0/2) 2960SW1 (G0/1)----------utp---------(G0/1) 2960SW2 (G0/2)---PC2
2960SW1:
configure terminal
vlan 10,20,30
interface G0/1
 switchport mode trunk
interface G0/2
 switchport mode access
 switchport access vlan X
end
2960SW2:
configure terminal
vlan 10,20,30
interface G0/1
interface G0/2
end
Verification:
show interface G0/1 (must be status up line protocol up)
show interface G0/2 (must be status up line protocol up)
show spanning-tree interface G0/1 (VLANs mustbe in FWD state)
show spanning-tree interface G0/2 (VLANs mustbe in FWD state)
show interface trunk
(Please post results here if still not working)
Please rate correct if this answered your problem.
Son
CCIE (R&S) #27666 CCSI HP MASE
Above scenario works perfectly fine, and i am able to ping both PCs, but i have to create the following scenario with No PC attached,
Had tried configuring both ports as trunk, but it didnt work, couldnt able to cascade.
If you are not using PCs, then how are you testing the connections? Are these physical problem (show ip int brief shows status down, line protocol down)?
