Cascading 2 cisco 2960 switch
Dear All,
I want to cascade two 2960 switch (Layer2) together, i have tried by making the ports trunk as well as access but it doesnt works, please help?
Jahanzeb Feroze
Dear Jahanzeb
Dear Jahanzeb
Please check the link below
http://www.tek-tips.com/viewthread.cfm?qid=1583402
Thanks for sharing the link,
Thanks for sharing the link, but question asked in that link is still unanswered, no solution has been determined yet.
Super Bronze
Could you expand on "doesnt
Could you expand on "doesnt works" in your OP?
And, as Jose already asked, could your provide configs and what ports you're actually interconnecting?
One port is of Gig, while
One port is of Gig, while other port is of Fa
Super Bronze
Copper?
Copper?
not copper, its ethernet
not copper, its ethernet cable
Super Bronze
Ethernet can run across both
Ethernet can run across both copper or fiber - so what "kind" of Ethernet?
Fiber
Fiber
If you are running fiber,
If you are running fiber, what are the SFPs you are using please do a "show inventory" Usually fiber SFPs are either 100Mps or 1Gbps, if only going to a 100Mbps device then ensure the SFP in the Gigabit port will run at 100Mbps
Hi Jahanzeb,
Hi Jahanzeb,
- Did you set a native vlan?
// switchport trunk native vlan <Vlan-id>
Example:
interface GigabitEthernet<int>
 switchport mode trunk
 no sh
Regards.
Nopes i didnt, is that really
Nopes i didnt, is that really matter to set the native vlan ?
VIP Purple
The native VLAN will default
The native VLAN will default to 1.  You don't need to configure it on either end, but if you configure it on one end you need to configure it on both ends.
Can you post the 2 config?
On first Switch,
On first Switch,
 switchport trunk allowed vlan <Vlan-id>
On other Switch,
interface Fa<int>
These are the simple config on both switches
VIP Purple
Have you created the VLANs
Have you created the VLANs being trunked on both switches, or just one of them?
Trunking a VLAN between switches is not sufficient to make it work.  You actually have to create the VLAN on both switches.
VIP Purple
Are the switches within 3m of
Are the switches within 3m of each other, and are they 2960-X's ?  If so, a nicer solution is to buy the stacking modules and make them look like one larger switch.
yes they are with in 3m,
yes they are with in 3m, cannot buy stacking modules, has to go with the same equipment which are already exists, one is 2960 while other is 2960 X
Hi Jahanzeb,
Hi Jahanzeb,
Here is a sample configuration for basic 2-switch connection.
PC1---(G0/2) 2960SW1 (G0/1)----------utp---------(G0/1) 2960SW2 (G0/2)---PC2
2960SW1:
configure terminal
vlan 10,20,30
interface G0/1
interface G0/2
 switchport mode access
 switchport access vlan X
end
2960SW2:
configure terminal
vlan 10,20,30
interface G0/1
interface G0/2
end
Verification:
show interface G0/1 (must be status up line protocol up)
show interface G0/2 (must be status up line protocol up)
show spanning-tree interface G0/1 (VLANs mustbe in FWD state)
show spanning-tree interface G0/2 (VLANs mustbe in FWD state)
show interface trunk
(Please post results here if still not working)
Please rate correct if this answered your problem.
Son
CCIE (R&S) #27666 CCSI HP MASE
Above scenario works perfectly fine, and i am able to ping both PCs, but i have to create the following scenario with No PC attached,
Had tried configuring both ports as trunk, but it didnt work, couldnt able to cascade.
If you are not using PCs,
If you are not using PCs, then how are you testing the connections? Are these physical problem (show ip int brief shows status down, line protocol down)?
382
