CAT 4000 - %SYS-4-P2_WARN: 1/Protocol Packet (is not present on cisco.com)
hi,
on a switch CAT 4000 , I HAVE this error:
2007 Jul 20 11:37:59 %SYS-4-P2_WARN: 1/Protocol Packet DA=00:02:44:b1:8f:f2 SA=aa:00:04:00:fb:17 arrived on unexpected port 5/30 cnt 2115
The port 5/30 is disabled.
I don't find this error on cisco.com.
Can you help me?
thanks
Fcostalunga
Re: CAT 4000 - %SYS-4-P2_WARN: 1/Protocol Packet (is not present
Though the above error is not seen in Cisco.com under the common %SYS-4-P2_WARN messages, it seems that a switch detected a loop and disabled the port.
How often are you seeing this Error? The SA is a DEC system. do use the same error if you move the source to another port?
Narayan
but , in this case , i don't understand the troubleshoothing that i can to do for to resolve my problem.
Can you have a link of this argument on cisco.com
Thanks for your help
FC
check the SA address in the CAM to see at what port it learns the address.
Is this being learnt at some other port rather than the one mentioned in the log...
i've search the 6 mac-address the i find in the log.
I find the 6 (six) port on this mac-address is connected.
the port is 6/40 , 6/43 , 2/40 , 2/39 , 2/42 , 5/6.
What can i do?
I can create an a VACL , or simply i disable this port?
thanks
FC
Fcostalunga,
I would like to check the complete logs for the errors that you are getting. Are you getting some "Astro timeout" errors as well. There have been a lots of bug associated with the kind of errors that you are getting and just want to be sure before getting onto this. Please sned me the complete logs.
HTH,Please rate if it does.
-amit singh
301
