Cat 4500 - dual SUP 7 - entservices license
mile.ljepojevic
I just looked all ten ports on SUP in slots 5 and 6 and I can see that Ten 5/3, Ten 5/4, Ten 6/3 and Ten 6/4 are inactive. I am not sure why and is there some restriction or should I add to the configuration?
Thanks.
9 Replies 9
Reza Sharifi
Are you sups configured for redundancy (SSO)?
what is the output of "sh redu"?
It is SSO
So, when connecting these 10Gig interfaces, do you see a link light?
No link light. Show interface command shows that ports are inactive. When I plug the same SFP and patch cable into Ten 5/1 or 5/2 it works. Only ports 5/3, 5/4, 6/3 and 6/4 are affected.
Just to add, software is IOS-XE 3.2.0
What is your license level?
entservices
from the config guide:
When you use WS-X45-SUP7-E in RPR or SSO mode,  only the first two uplinks on each supervisor engine are available. The  second two uplinks are unavailable.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/01xo/configuration/guide/RPR.html#wp1159040
Thanks.
I found that too, I was just not sure if there is anything that can be done to make them active
