Cat 4500 Redundancy
All,
I have a 4507 R as core , but I would like to add another one as failover for the existing one. Besides the fact that they have to be the same , what is to be done exactly . Does anyone know step-by-step?
Hall of Fame Super Bronze
Re: Cat 4500 Redundancy
This URL should help:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/37sg/configuration/guides/NSFwSSO.html#wp1131609
Concentrate on the 'configuring SSO' portion of this document. NSF is for the routing protocols.
Another good link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/37sg/configuration/guides/RPR.html
HTH,
__
Edison.
Edison as usual your info is always Gold !!
Wanted to provide in some additional info in case OP wants to add a second 4507R chassis .
You can have dual collapse core
implementation, you have options of implementing HSRP and/or GLBP, but initially you can start looking at hsrp to provide active/standby architedture to start with and look into glbp later, with current 4507R
you can 802.1q trunk and etherchannel the two gigabit ports off the sup engine via fiber at each core and work on hsrp group between the two switchs svi interfaces.
etherchannel is not required but u should look into it.
If you have single sup you then do not have hsrp which then will make the implementation even esier utilizing your current SVI ip address as the hsrp address so that you do not have to chnage hosts with new defaul gateway.
Have a look here - high availability guides,
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns431/c649/ccmigration_09186a008093b876.pdf
HSRP
http://www.cisco.com/en/US/tech/tk648/tk362/tk321/tsd_technology_support_sub-protocol_home.html
Configuring trunking and etherchanneling
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_configuration_examples_list.html
LAN switching configs
this is example created from examples from abouve links
example for one vlan ( both primary/secondary cores A and B)
1- create l2 vlan 2, set vtp parameters
2- create 802.1q trunk (obtional)--> and etherchannel group
3- create L3 SVI interfaces e.i vlan2
4- assign ports vlan memebrship to access ports
COREswitchA
vlan database
vtp domain cisco
vtp server
vtp password cisco
vlan 2 name test
interface Port-channel 1
switchport mode dynamic desirable
no shutdown
interface GigabitEthernet0/1
switchport trunk allowed vlan 1-4094
channel-group 1 mode desirable
no shutdown
interface GigabitEthernet0/2
no shutdown
interface vlan2
ip address 10.0.0.1 255.255.255.0
standby 1 ip 10.0.0.3
standby 1 preempt
standby 1 priority 110
standby 1 authentication vlan2
standby 1 timers 5 15
no shutdown
and so on....
CoreswitchB
vlan database
vtp domain cisco
vtp server
vtp password cisco
vlan 2 name test
no shutdown
no shutdown
no shutdown
interface vlan2
ip address 10.0.0.2 255.255.255.0
standby 1 preempt
no shutdown
etc..
Default gateway for internal hosts will be 10.0.0.3
and so on...
Jorge
224
