I must be having a thick moment. Are all the ports on the 24LC capable of POE but the limitation is that the switch can only support 4 ports due to power max at 60w?
Also, is the way to set POE on a port to set the port to an Access Point? The whole Smartport concept is very limiting.
I want to run IP Camera's on POE, but can't seem to find any reference to how to set a port to POE other that as an AP.
Any points would be appreciated.
