CAT 6500 Issue
vinoth.kumar
HI,
We are using two CAT 6506 in our network and planned to deploy the Redunancy between this two CAT and configured and HSRP
for example :
In Primary CAT
VLAN 101
interface vlan 101
IP address 10.101.1.2 255.255.255.0
Standby 1 IP 10.101.1.1
standby 1 priority 110
no shut
In Sec CAT :
VLAN 101
interface vlan 101
IP address 10.101.1.3 255.255.255.0
no shut
Now i have enbled one port to the corresponding VLAN 101 in both the CAT and connected to the downstream switch
what happens is iam not able to connect or ping to the Standby IP 10.101.1.1 if i remove any one of the cable connecting to the downstream switch i am able to ping
i am not sure what might be the issue may be because of STP since two cable are connnected to downstream switch
can any one help me on this
Thnaks
Edison Ortiz
Are you able to ping the physical IPs when you are unable to ping the standby IP?
Where are you pinging from? From a device connected to the downstream switch or from a device connected to one of the Cat6k switch?
Are you able to ping the standby IP from the switch itself when the problem occurs?
___
Edison.
I am trying from the PC connected to the Downstraem switch
iam Not able to ping the Physical as well as standby IP when two cables from both CAT is connected
in the PRI CAT when i issue the command sh standby its is not showing the secondary cat IP
can i know which is best option to achieve redunancy in this snerios
So the problem is not due to the HSRP configuration but you are having a Vlan101 issue.
Make sure the downstream switch also has Vlan101 on its database and the inter-switch link (assuming it is a trunk) is also carrying Vlan101 in the forwarding state.
If you post configs, we may able to help a lot faster.
As for best option for redundancy, HSRP is a solid solution.
__
Edison.
