Community Member
cat 6500 switches
Hi all
With Cat 6500 switches, do they run the normal IOS ?
Do they have a startup wizard for the config?
Are the blades in them hot swappable?
Are the supervisor modules both in use or are they active standby?
cheers
Carl
Re: cat 6500 switches
With Cat 6500 switches, do they run the normal IOS ? Yes, they run IOS. They have the same CLI as all the other platforms.
Do they have a startup wizard for the config? Yes.
Are the blades in them hot swappable? Yes.
Are the supervisor modules both in use or are they active standby? Active/Standby.
Community Member
Many thanks for your reply
are there any other things that are very much different to the other closet switches on this then?
do they have a gui for configuration?
do the modules have 10 gig sfp slots and how many ports are in them?
cheers
Carl
>>switches running IOS but not L3 capable would obviously have no routing capability.
do they have a gui for configuration? Not for 6K.
do the modules have 10 gig sfp slots and how many ports are in them? No not SFP, they have 10 Gig but it does not take SFP, they take X2 transceiver.
Community Member
Hi there ,what do you mean, for 6k?
sorry, i meant do they support 10 gig XFP? how many of these ports are on one card?
is there any cisco courses on these switches ?
Hall of Fame Super Gold
There are two "types" of IOS codes: Monolythic and Modular.
Regarding the 10GE blades:
WS-X6708-10GE
WS-X6704-10GE
WS-X6716-10GE
Both require SUP720 supervisor cards to work.
Each supervisor card (SUP720 or SUP32) has 2 10GE ports.
Here are some informations you might want to look at:
10-Gigabit Ethernet Transceiver Modules Compatibility Matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html')">www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
Cisco Catalyst 6500 Series 10 Gigabit Ethernet Interface Modules
www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a00801dce34.html
Cisco Catalyst 6500 Series10 Gigabit Ethernet Modules Data Sheet
www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns224/ns668/net_business_benefit0900aecd805348f3.html
Does this help?
164
