Cat - 6506-E Hybrid
Can some one post a sample configuration of the above mentioned catalyst(Cat OS on the Layer 2 and IOS on the Layer 3)which is live.
Thanks in Advance,
subra
Hall of Fame Super Bronze
Re: Cat - 6506-E Hybrid
Please refer to the documentation for sample configuration and how to configure services on each Operating System:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/index.htm
For CatOS, you can select "Catalyst 6500 Series Software Documentation, 5.5 thru 8.6"
(Depending on the CatOS version you are running).
For IOS, you can select "Catalyst 6500 Series Cisco IOS Software Documentation, 12.1E or 12.2SX"
HTH,
__
Edison.
Thanks for the response.
All I am looking for is like a "Best practices with Cat 6500" or configuration from a Live setup which is optimized.
Subra
Hall of Fame Super Blue
Subra
Have a look at the following documents for 6500 switches which should get you started.
Best practices Configuration & management - CatOS
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080094713.shtml
Best practices Configuration & management - IOS
http://www.cisco.com/en/US/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml
Best practices Operational
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd805457cc.html
Jon
329
